phpconstant(
VALUE
The phpconstant( function encodes text for use as a contant in a php program.
value – the value to be encoded. This value may be text, in which case it will be properly quoted. Any special characters in the text will be escaped. The value may also be numeric, in which case it is passed thru “as-is”.
This function encodes text for use as a contant in a PHP program.
phpconstant("he said 'boo' then left") ☞ 'he said \'boo\' then left'
phpconstant(3264) ☞ 3264
- applescriptconstant( -- converts an expression into an AppleScript literal.
- javascriptconstant( -- converts an expression into a JavaScript literal.
- javascriptstring( -- converts a text string into a JavaScript string
- perlconstant( -- encodes text for use as a constant in a Perl program.
- pythonconstant( -- encodes text for use as a constant in a python program.
- rubyconstant( -- encodes a value for use as a constant in a Ruby program.
- runningappinfo( -- returns information about applications that are currently running on this computer.
- Scripting Panorama X with AppleScript -- embedding Panorama code into AppleScript (allowing Panorama to be controlled from other programs).
- unixshellstring( -- encodes text for use as a parameter to a unix shell command.
