endnoshow
The endnoshow statement resumes the output of text and graphics after it has been disabled with the noshow statement.
This statement tells Panorama to resume all output of text and graphics. Although output will resume after this statement, the endnoshow statement does not update the display. To show any changes that have been made since the noshow statement you should use showpage, showline, showfields, showvariables, showcolumns or showrecordcounter.
Here is an example that performs several operations on the current database, but only updates the display once.
noshow
field Date
groupup by month
field Category
groupup
field Amount
total
outlinelevel 2
showpage
endnoshow
- endshowlater -- resumes the immediate display of text and graphics after it has been deferred with the showlater statement.
- fontcharacters( -- returns a string (text) containing all of the characters supported by the specified font.
- fontinfo( -- returns a dictionary with information about a specified font.
- hide -- temporarily disables the output of text and graphics.
- info("computername") -- returns the name of the computer (as set up in the System Preferences Sharing panel).
- info("runningatomic") -- returns true if the current procedure is running as a "atomic" procedure.
- measuretext( -- returns the size of a string of text in a particular font and size.
- setbannericon -- sets the icon on the right side of the toolbar banner.
- setbannermessage -- sets the text in the toolbar banner to an arbitrary message.
- setbannerprogressbar -- displays progress in the toolbar banner.
- show -- resumes the output of text and graphics after it has been disabled and then forces Panorama to redisplay all windows in the current database.
- showlater -- defers the display of text and graphics until the procedure is finished.
- showline -- forces Panorama to redisplay the current record in all windows in the current database.
- showother -- forces Panorama to update some data on the screen.
- showpage -- forces Panorama to redisplay all windows in the current database.
- Timer Workshop -- provides a tool for monitoring timers and testing timer configurations.
- timerexists( -- checks to see whether a timer exists.
- Timers -- executing recurring periodic background code at fixed intervals.
- Understanding the Run Loop -- explanation of how Panorama code interacts with the run loop to respond to mouse clicks, keyboard presses, display updates and other events that require attention.
- wait -- pauses the program for a specified period of time.
