tc24to30(
TIMECODE
The tc24to30( function converts 24 frame timecode to 30 frame non-drop timecode.
timecode – text value containing timecode
Converts 24 frame timecode to 30 frame non-drop timecode. (Submitted by Chris Watts)
tc24to30("01:00:01:23") ☞ 01:00:01:29
arrayrange(timecode,1,3,":")+":"+getdictionaryvalue(Convert24To30Dict,arraylast(timecode,":"))
- feetandframes( -- takes an integer and returns a feet and frame count for 35mm film.
- kcadd( -- takes a keycode for 35mm film and adds a number of frames to it and returns a keycode as a string.
- kcdiff( -- calculates the number of frames between two frames of 35mm film, using inclusive counts (submitted by chris watts)
- kcframes( -- returns an integer based on a feet and frames count for 35mm film.
- kcoutfromlength( -- answers the question "what will the last frame be if i start my cut at the incode and my shot is some number of frames long"?
- outcode( -- adds one frame to a timecode.
- tc30to24( -- converts 30 frame non-drop timecode to 24 frame timecode.
- tcadd( -- accepts a timecode as text, and adds some number of frames, returns a timecode string.
- tcdiff( -- calculates the number of frames between two timecodes.
- tcframes( -- returns a number of frames from zero of a 24fps, 25fps, or 30fps timecode.
- timecode( -- returns a timecode string corresponding to an integer.
