tcadd(
TIMECODE
OFFSET
FRAMERATE
The tcadd( function accepts a timecode as text, and adds some number of frames, returns a timecode string.
timecode – text value containing starting timecode.
offset – integer value (number of frames to offset).
framerate – integer value (usually 24, 25 or 30).
Accepts a timecode as text, and adds some number of frames, returns a timecode string. Works with 24, 25, and 30fps timecode. (Submitted by Chris Watts)
tcadd("00:00:00:00",100,24) ☞ 00:00:04:04
timecode((tcframes(textcode,framerate)+offset),24)
