setbannerprogressvalue
VALUE
DATABASE
The setbannerprogressvalue statement displays progress in the toolbar banner.
value – is the progress value, from 0 to 1. For example 0.5 indicates that the current task is half complete.
database – is the database where the progress is to be displayed. This parameter is optional, if omitted or empty, the current database is used.
setbannerprogressvalue 0.6
Note: The progress bar will appear in all data windows associated with the current database, not just the current window. You can also specify that the progress bar be displayed in a different database, like this:
setbannerprogressvalue 0.4,"Checkbook"
