csvquoted(
TEXT
The csvquoted( function adds quotes if necessary for CSV text (RFC 4180).
text – the original text.
This function can assist with exporting CSV text (see RFC 4180). If the text contains a comma, double quote ("), carriage return or linefeed, it is surrounded with double quotes, and any double quotes within the text are turned into 2 double quotes. Otherwise, the text is left alone.
csvquoted({David Smith}) ☞ David Smith
csvquoted({Smith, David}) ☞ "Smith, David"
csvquoted({John said "It's ready!"}) ☞ "John said ""It's ready!"""
- csvexportline( -- generates a comma delimited line of data containing all the fields in the current record.
- csvexportlinevisiblecells( -- generates a comma delimited line of data containing all the visible (non hidden) fields in the current record.
- HTML Export -- custom exports into an HTML file.
- Text Export -- exporting a database into a text or HTML file.
- Text Export Wizard -- custom exports into a text or HTML file.
